Greg,
Someone mentioned disconnects, and emergency disconnect is not required for resi spas, but a disconnect for the motors is still required to be within 50 feet and within eyesight of the motors, if it is not part of the spa package. As for bonding concrete on existing patios around here some EC's are installing rubber mats around the tubs or wooden decks, this way you are insulated from the concrete.
