Here (Austria) generally licensed electricians have the right to cut seals, make repairs and fax the reconnection form (which only tells the PoCo: "Come here and seal the meter again whenever you like, I told you the meter is unsealed so it's your responsibility!". Usually that happens when they read the meter the next time.
They also reserve the right to visually inspect the service and panel prior to resealing, but rarely do so other than having a glance at the meter (hard not to do ;))
