I have a friend who has installed a motion switch in his closet. He says it works fine on incandacent bulbs but not on a "Daylight 6500K CFL". First question: Is this normal or has he possibly got a "bad or cheap switch"? He asked me also if I knew of a simple relay I could recommend. I don't deal in relays too much, though I have in the past, so I would only know to tell him a simple "plug in relay"and base, that was rated at at least the amperage of the load he has on it. I imagine the lowest rated one is probably rated maybe 1 amp?? I'll probably just tell him to go to the nearest electrical supply house and ask them. He lives a few hundred miles from me so I can't go and check it out for him:) Thanks for the help. Steve..
