I dont understand if the current and voltage does not have a direct impact then why is there less voltage on one bulb when illuminated.I have found a similar example in a text book and it says "due to the phasor addition of the voltage in the circuit then one set of bulbs will be dim"(they used two lamps in that example).
I think im missing something really silly here!!!!
