Edwards makes a trip switch that literally hangs in the path of the door swing. Once the door hits it, it makes a momentary contact. It's designed to NOT make contact again when the door closes. Most supply houses carry the Edwards brand, but if your's doesn't, try an electronics specialty store. Edwards' part number for this is #236 and it appears that Rexel carries this brand.
