thanks Matt, i don't have time to check it tonight but i do remember now about derating before the 125% is applied. and using 110.14 screws me up too. if you use xhhw for instance, and the terminals are rated for 90*C then i assume you can use the column. going back now to edit my post so nobody gets messed up
