My question is whether using the fan on 230V50Hz(using a transformer) would negatively impact the fan.
-Would the motor burn out?
Shorten the motor life?
-Alot of extra heat generated?
Burn out? Probably not.
Shorter Motor Life? Probably
Extra Heat? Yes!
What is so special about this fan? You can probably find local version that is designed for the local power supply and not risking burning down the building you and your family live in, by kludging some together.
