normally i used the Kholer or Onan both are very good to me.
just make sure you get sound enclosure with it [ it will cost little more than standard units will charge ]
the other thing is check the warranty as well
but Dave just a head up if you get natural gas genny make sure you give the coumster a head up may have to change the gas metering to handle extra load on it .
Merci , Marc
