I'm not a great fan of any version of Windows, but I do have 98SE on this system I'm using at the moment.
I don't like XP one bit. One client has it on his main system, and I've found it to be an absolute pain trying to port DOS applications to it. I've wasted hours trying to fine-tune settings to get the display correct and to let the application access printers etc. without XP "getting in the way." Same goes for ME.
I've yet to see Vista, but by all accounts I've seen so far it's all window dressing (no pun intended!) and little actual substance. Time will tell, I suppose.
I see no point in upgrading to something just for the sake of it, and will quite happily use old versions of an O/S or package if it does all that's required of it.
Another place I maintain the computers/software for is using custom software that I wrote with Turbo Pascal 5, under DOS 4.01 O/S. It's quick, reliable, and doesn't use a gazillion bytes of disk or RAM to do its job.
