I have a POCO dedicated pad mount (50kva) approx 90 ft from service eq.
My recorder indicated that incoming voltage has varied from 127.1 to 123.9 over a period of 12 months.
Dedicated transformer and a voltage recorder? You sure are an engineer!
Aren't those figures a bit high? Sounds as if you could extend the life of your lightbulbs quite a bit by lowering the voltage...
[This message has been edited by C-H (edited 11-03-2002).]
