These clips likely expect the male plug prongs to have that small hole at the ends. The clips probably have something that anchor to the prong so it doesn't come off when you pull the plug from an outlet. Also, the plastic face of the outlet probably serves to keep the clips from shorting together.
Back then, good conductive spingey material likely wasn't perfected yet for use to manufacture the contacts inside outlets.
