We work on the utility crew at a coal fired power plant, where we do a lot of work with large vacuum trucks. The issue is we are constantly getting shocks from static build up in the vacuum hoses, especially when vacuuming ash and coal. Adding to the problem is the fact that we are located in Wyoming, where it is high and dry. The low humidity adds to the static problem. The questions are as follows: 1. Are the static shocks we are recieving harmful to a persons health? 2. What is the absolute best way to keep from getting shocked and still get the job done safely?
