If it helps any... the NMC is for temporary use only and will be removed as the permanent wiring is put in place and energized.
I am also aware that even the permanent wiring cannot be used for power during construction unless it is GFCI protected.(not necessarily the wiring in this case but definately any 120V receptacles)
Being that I am no longer the boss, I cannot control how temporary wiring is installed or used. I do feel that even the wiring should be GFCI protected but am not sure.
Please keep the responses coming.
