I went out yesterday to run power out to a 28 ft. mobile home which has been located in a backyard for an eldest son to use.
It came from a nearby campsite at Happisburgh, where it appears individual meters are installed in each caravan.
The standard of wiring leaves something to be desired. The original SWA (armored) supply cable was just cut underneath, so this is exactly as the service had been operating:
Meter removed with old connections intact:
(Sorry about the lousy quality in the first photo. My cheap digital camera has no flash and doesn't handle dimly-lit areas at all well.)
[This message has been edited by pauluk (edited 04-09-2004).]
