check out this one, just for the picture
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=3265115638&category=23325
short partially translation:
"The supply cable is equipped with a high quality copper-shielding, blocking HF fields not to disturb the Power supplying of your high end audio equipment. Due to the high purity of the copper (addition by me: !!!), the cable has a very low resistance (0,017 Ohms per wire). This guarantees an impulse-fairly supplying. The shielding quality of your equipment gets optimized, when you use our cables on all your pro audio equipment. "
"The phase is marked, so you can easily connect your appliances." (add by me again: IDIOTS! Plug reversed, phase isn't phase anymore).
My conclusion: I hate sellers like these. What do you call them guys, that cheat on people this way and want 39 Euros for 5 Euro crap?
High copper purity, what the "?%², the hundreds of meters supplying wire to the outlet, as well as Plug&Receptacle don't have any resistance, do they...
p.s. 0,017Ohm per 1,4m at 1,5mm² calculates out to the standard specific copper resistance. Very high elite purity.
And these Ferrules, pure silver i guess.
And: They didnt even connect the shield to ground [Linked Image]
perfect disturbance from oscillating capacitive load on the shield.
What's your meaning on this product of the year?
[This message has been edited by :andy: (edited 01-06-2004).]
