I am designing a system to go into a plant in France. The information I received wrt their power supply in the plant is 400vac 3ph with an ungrounded neutral. (I am assuming Y with the neutral connected to the ungrounded center tap)
Does this make sense or is their something lost in the translation?
Also wrt to conductor color, I assume this neutral conductor should be blue.
