You mean to say that you wrecked a perfectly good valve amplifier, because you didn't know how to trace a simple circuit?.
Hell, you should be ashamed, because if you can't trace a valve (toob) circuit, there is nothing simpler.
Hmmmmm.
When I got it, it was partially scrapped. This was actually the first tube amp I got, and I may have been able to figure out part values with the knowledge I have now, but not then.
I did save the transformers and 807's tho
. Never did get to rebuilding it, that's my current project (I'm turning it into a guitar amp, hence my question about the 7800 regs in the Theory forum)
