Unless your two service providers share a common pool of dynamically allocated IP addresses (unlikely unless one is a subsidiary or affiliate with the other), then yes, you'll have a different IP address.
Have you posted here with the second ISP yet? I just had a look at the addresses on some of your posts in the non-U.S. area and they are all showing up as belonging to Telecom Internet Services of NZ Telecom.
