Scott35 brings up an interesting concept in his last "full" posting.
Having a capacitor as part of the load and drawing vis Current makes it hard on a set of contacts.
Considering that a relay coil could be fed via the Collector of a Power Transistor, makes the transistor vulnerable to over-currents from the coil.
Cascading relays/contactors,for more or heavier contacts makes this situation worse.
