TVSS is made by all the leading manufacturers as well as many after market people. Check out Power Quality's website.
As for your ballasts, sure, seen that a bunch. fuse each one at the bottom of the pole base at just above the normal draw takes care of a lot of the problem, you may lose a fuse occasionally, but rarely anything else. Made by AB Chance, Cutler hammer, and Bussman, I think Bussman makes the best ones.
