The Britisch standard for 1Ø meters is usually Phase in, Neutral, Neutral, Phase Out.
That's the order I've always known, and as you say, the terminations for the potential coil can often be seen quite easily.
On dual-tariff meters there's an extra smaller terminal squeezed in for the selector solenoid, often between the load-side phase and neutral.
