Most trusses are not supposed to be supported mid span, they are only supported on each end. The bottom cord of the truss is under tension and has virtually no downward force. The connection to interior wall is to keep the trusses in line and hold the wall plumb. This is often done with L-clips or toe nailing.
Curt
Curt Swartz
