How do you clean or wash these?
It looks like they'd get disgusting easily
you didn't put the garbage directly in these. there was another can that fit inside adn could be lifted out to dump into the truck. so basically the garbage never came into contact with the "manhole". im sure they probably had holes in the bottom for drainage so you could wash them out when they did get stinky
