Shouldn't this have some sort of a recept on it?.
Would you be allowed to use an European outlet meant for 220V 50Hz at the appropriate amp rating? It wouldn't have the "UL" on it, but would the European approval be acceptable? Using the European outlet would prevent someone from plugging in a load that wants 60Hz. And it would be obvious to the userd that that outlet is the 50Hz one.
