Transposition Pole - Again...
Hello all;
Here are a few shots of a Transmission Pole with Transpositions on it.
Two individual 3Ø Circuits, Voltage is like 138 KV (???).
Images shot in North Hollywood / Sun Valley, and these Circuits may be for City of Glendale DWP - if not, then would be LADWP's stuff.
These Circuits are
"Rolling Away From Each Other" - whereas the previously posted image shows both Circuits
"Rolling At Each Other" on the 66 KV Pole.
The Circuit on the Left-Hand side "Rolls" from "Top To Bottom" (Phase at the uppermost part is brought down to the lowermost position, and remaining two Phases move upwards in position).
The Circuit on the Right-Hand side "Rolls" the opposite way - from "Bottom To Top".
Images below---
Image #1: Distant Overview shot of Transposition Pole
Image #2: Cropped close-up from above Image (Image #1)
Image #3: Sort-Of in front of the Pole shot...
Image #4: Cropped close-up from above Image (Image #3)
I will try for better view(s) next week!
Scott35
Edited to fix UBB / HTML tagging "Suck Script" problem
(forgot a "/" slash in a tag - which resulted in "Suck-Script")
[This message has been edited by Scott35 (edited 12-11-2004).]
