now that is the disator is waiting for happending anytime
harold did you try to get ahold of the homeowner beside the babysitter try to scoot you out?? i will concat the homeowner about the sisuation asap.
i can see about first two motors but one thing it do bother me is what size the wireing on for motor grounding there ?? i know it should be #8 and if i rember the rules right [ correct me if i am wrong here] it should not have any splices at lug connectors at all and the wire have to be concouns with out splice along the way.
third photo show no ground wire for pump motor at all and i think this is very dangerous pratice myself i did see few pool and few hot tubs do the same ways and i am not comfotable with it. and do this system is procted with GFCI devices ??
Merci , Marc
