scjohn-
I'll assume you are talking about 240 volt, single phase, baseboard heaters. I'll also assume they are rated at 2000 watts.
Using the following voltage reduction formula:
208/240^2=.75
Your 2000 watt heater will now be reduced to a 1500 watt heater. If that doesn't present a problem don't do anything.
Frank
