This is a configuration I found on a new chiller set up. There is a 400 amp feeder that comes from the MDP in a separate room, it comes into a large Hoffman box, someone mounted 2 sets of 200 amp fuses, and ran to the two chillers.
No disconnecting means in either the box or the control cabinet. Check out the greenfield supports on the 2nd chiller, and the control wiring coming down into the enclosures from above.
