here what is see.
pic 1. i like the chase nipple in the middle,see the lock nut.and how are these switches mounted.on the cover.?
pic 2.i like the split bolt connector,even with that it looks like the one wire is not in it.
pic 3. nut is missing for the bolt for the ground strap
pic 4.need a double lug
pic 5.looks like someone cut the pre form elbow to short and the coupling is not sealing right.also where the other lug and wire on the other bushing.
pic 6. the metal shavings is from the buss bar.that they drilled to install that over size lug.also they did not mark the wire with green tape.
