Other than calling the HVAC contractor for a cut sheet, is there a way to calculate breaker sizes and wire sizes for HVAC units such as roof top units?
Example: 20 ton RTU 480V 3 Phase
(Gas heat)
What should the breaker size be and what should the wire size be? Also, what will the running amps be? (I do realize that it may vary slightly from brand to brand.)
