NJ
I heard everything from turning on everything and taking an amp reading to just imposing the maximum fine , which I think is $10,000.00 for tampering with thier equipment, when i find out I'll let you know.
They had Washer,Dryer (elec), band equipment ( guitars, amps, etc), a fridg everything in the basement and some kit upstairs,
the real bad thing here is it was a 3 family so not only would this bonehead kill himself and his family he would have taken down a couple other families .
which reminds me to check the dates on his smoke detectors too ,,,
right now fixing the violations , will probably cost him about 1,500
then the new service 4 meter's 4 panels will go about 5,500
and if his smokes are outdated another 1,000
oh and did ya like the panel on the right?
looks like he put that in too , no locknuts , no connectors , and it's a 1 1/4 nipple and the KO is knocked at 1 1/2 ,
and FPE to boot ...
and see if you can trace the wires in picture #3 to the breakers,,,
And there is NO OCD all the way from the meter to that sub panel and whatever else is tapped on to before it .
HV
