The first few are from our "Comapny Inspections" at the FD in our industrial park. (It used to be the Chicago Hardware Foundry from 1890-1965, then it got subdivided to new uses, so it's full of interesting handiwork)
Pic #1 is of a new support for a Service Entrance - call it a "Service Ladder" if you will...
- DougW
Pic. 2 is in the same area - guess the supporting means for the service entrance finally gave way; the only thing holding the assembly up is the crossbot the the neutral goes to.
Pic 3 is from a stop at a gas station. Yes, that is a plumbing fitting on the electrical conduit.
Pic 4 is from a commercial job I was helping a buddy with. He got the call because the site had failed it's final due to "loose fixtures". (another EC was responsible for construction - he got hired to clean up after them)
The original "electrician" took the mounting bracket for the HID pack and installed it backwards. He even took the time to cut the slot for the bracket projection in the siding plate. Of course, the bracket projection is part of what keeps the fixture stationary... The handyman the restaurant hired sank several drywall screws at the top corner of the fixture to keep it from moving. It didn't work.
