i allready see it before on one place and it did actally rip the LB right off and i have to repair it and deletes all the LB fitings and redo it propely if i see it again i will make sure the service mast insluaters are off the conducts btw if they are 2 inch rigid maybe can use but i doubt as i see the picture and someone dont relazie that the constant tenson can pull it off over the time
merci marc
