Greetings ~
Can you inform me of the CEC residential requirements for any grounding electrode,and type needed ,in addition to the feeder ground conductor, at the detached structure,when a feeder is installed from the building where the primary service is located?
I also would like to know where this residential feeder disconnect is required to be located at this detached building.
Many Thanks
