Admin 16
ESA Arc flash course
by TheShockDoctors. 03/24/17 10:15 AM
fuse rejectors
by HotLine1. 03/24/17 07:53 AM
Another Forum Update
by Admin. 03/22/17 03:04 PM
Dining room plugs
by watersparkfalls. 03/21/17 10:31 PM
TRUE POWER
by jraef. 03/21/17 09:13 PM
SE cable question
231,369 Are you busy
166,092 Re: Forum
160,560 Need opinion
0 registered members (), 59 guests, and 11 spiders.
Previous Gallery
Next Gallery
Rate This Thread
Images In This Group
SE cable question
by Jdscott2005 on 02/07/17 09:23 PM
Hey guys, this is my first post so thanks in advance for your help.
I'm replacing a 100A service panel and it is on a 3ft wall that runs perpendicular to the exterior wall and this wall is lined up with the meter socket. The inspector said I will not need a disconnect if I am within 5 ft and that I should put the SE cable in pipe...
What type of "pipe" should be used for this 2/2/2/4 SE cable? Should I take my box down and make a hole in the side so I have a straight run? I am very close to that 5ft max the way I have it now running to the top of the box. I assume wire length inside the boxes are not counted toward that 5 feet?
Remind me of what size wire and ground rod I will need to add to this system please. The ground from panel to meter box is #4 aluminum
Comments
#218200 - 02/08/17 06:10 PM Re: SE cable question [Re: Jdscott2005]
HotLine1  Offline
Brick, NJ USA
Copied and relocated to General Discussion area
Please post comments there.
Super Rod Cable Installation Tools
Super Rod Cable Rod System
Super Rod Cable Rod System -
Voted
Best Product of the Last 50 Years by members of NICEIC
BEAMEUP
BEAMEUP
WA
Show All Member Profiles
2017 NEC and Related
2017 NEC
Now Available!
Shout Box
Powered by UBB.threads™ PHP Forum Software 7.6.0
Page Time: 0.015s Queries: 18 (0.004s) Memory: 0.7492 MB (Peak: 0.8797 MB) Zlib enabled. Server Time: 2017-03-25 01:51:35 UTC
