The Electrical Contractor Network
ECN Electrical Forum
Discussion Forums for Electricians, Inspectors and Related Professionals
Books, Tools and Test Equipment for Electrical and Construction Trades
Live Chat
Join in a Live Electrical Chat!
>> Enter/Register
  Sorry, your browser is not Java enabled, please visit our java support pages in Chatroom
Looking for a unique adjustment nut
by HotLine1
02/09/12 07:14 AM
A taper or B taper, which is it?
by JoeTestingEngr
02/09/12 12:39 AM
GE low-voltage remote control relay system
by Albert
02/08/12 10:26 PM
Electrical systems in mobile structures.
by gfretwell
02/08/12 09:21 PM
Conduit Bending Apps for iPhone -Master Bender
by KJay
02/08/12 08:31 PM
A What's right here??
Shout Box
Top Posters (30 Days)
gfretwell 72
HotLine1 68
KJay 34
sparky 28
renosteinke 26
Classified Ads:
Electrical-Classifieds.com
Who's Online
0 registered (), 119 Guests and 3 Spiders online.
Topic Options
Rate This Topic
More sloppyness at BK
Image Details
Poster wa2ise Offline
Posted 02/05/10 05:06 PM
Description
This picture didn't come out that clearly, but look carefully and you'll see wire nut connections just above the plastic light defusser plastic sheet in this ceiling light fixture. This at the same BK I posted that picture with the bad ceiling outlet with the extension cord running to up above the suspended ceiling... We probably don't want to know what else is above the ceiling tiles...
Dimensions 369x234
Size 12.14 KB
UBBCode
Thumbnail
Medium
Full
Comments
#192308 - 02/06/10 11:42 AM Re: More sloppyness at BK [Re: wa2ise]
HotLine1 Online   content
Loc: Brick, NJ USA
This may be the 'handi work' of a ballast changer??
_________________________
Top
#192335 - 02/08/10 06:12 PM Re: More sloppyness at BK [Re: HotLine1]
aussie240 Offline
Loc: Blue Mountains, NSW, Australia
Reminds me of when all the PCB filled phase correcting capacitors were changed in the lights at my place of work.
The new polyester film capacitors had different mounting arrangements of course. Naturally, the contractors weren't going to waste time installing new mounting clips with several hundred light fittings to be done. So the capacitors were simply left resting on the cover plate to dangle down by their leads when the cover is taken off.
Top
#192484 - 02/15/10 07:17 PM Re: More sloppyness at BK [Re: aussie240]
Trumpy Offline
Loc: SI,New Zealand
Yeah Aussie,
I remember in the early stages of my electrical apprenticeship working on troffers with the old PCB ballasts.
I seem to remember how nice it was that the manufacturers (Thorn, I think) rivetted the ballasts to the top of the troffer body.
One morning I was working in the editorial office of our local newspaper, removing these ballasts and replacing them with wire-wound ballasts.
The first person into the office that morning turned on all the lights, so that when I turned up, the ballasts were too hot to touch, let alone hold while you drilled the rivets out.
One other thing I remember too, was that the wiring they used inside the troffers had a habit of having it's insulation go brittle, due to the heat inside the fitting.
I only had to be taught that lesson once, as the place had to have as many lights on as possible as the staff were proof-reading and checking colours and what-not as I worked.
For a split second, they had all the light they needed, when I took the cover off one of the troffers.
The insulation fell off all of the wires and shorted to the troffer case. mad
Let's face it, these days if you're not young, you're old - Red Green grin
Top
#192521 - 02/16/10 07:09 PM Re: More sloppyness at BK [Re: Trumpy]
Loc: Brick, NJ USA
Mike:
You're bring back memories....
Opening up a fixture & finding the 'real old' ballast still inside, with a 'newer' one stuffed in. was kind of commonplace when someone didn't want to dispose (legally) of the PCB ballast. It was a real pain in the butt on the 8', 2 lamp 96 channels too.
Top
#192527 - 02/16/10 08:32 PM Re: More sloppyness at BK [Re: HotLine1]
frenchelectrican Offline
Loc: Wi/ Paris France { France for ...
I have see that issue couple time when doing the troubleshooting and someone stuff very old school ballast and never bother take it out and few luminaire I did work on it did show a bow line so I knew i will be running hevey luminiare ballast { try to find old 25 HZ ballast then you will get the idea }
Merci,Marc
Top
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
