The Electrical Contractor Network
ECN Electrical Forum
Discussion Forums for Electricians, Inspectors and Related Professionals
Books, Tools and Test Equipment for Electrical and Construction Trades
Live Chat
Join in a Live Electrical Chat!
>> Enter/Register
  Sorry, your browser is not Java enabled, please visit our java support pages in Chatroom
Accessing J-box behind luminaires
by sparkyinak
05/17/12 01:29 AM
Back to back bends on electric bender
by sparkyinak
05/16/12 11:37 PM
100AMP panel in 60 degree ambient what size wire?
by twh
05/16/12 11:10 PM
480V motor vs 208V on VFD's
by sparkyinak
05/16/12 12:41 AM
Braking of single phase induction motor
by gfretwell
05/14/12 01:57 AM
An old Amprobe model 550
Shout Box
Top Posters (30 Days)
HotLine1 24
gfretwell 21
sparkyinak 15
twh 14
renosteinke 12
Classified Ads:
Electrical-Classifieds.com
Who's Online
0 registered (), 77 Guests and 2 Spiders online.
Topic Options
Rate This Topic
Crawfoot extension cord
Other images in post
Image Details
Poster wa2ise Offline
Posted 01/11/10 12:23 AM
Description
Another oldie. This extension cord would probably work well in Australia.
Dimensions 751x503
Size 76.79 KB
UBBCode
Thumbnail
Medium
Full
Comments
#191756 - 01/11/10 05:34 AM Re: Crawfoot extension cord [Re: wa2ise]
aussie240 Offline
Loc: Blue Mountains, NSW, Australia
My guess is that it uses green/white/black conductors in the cable. What way round are the black and white conductors...and are they the same at both ends?
Also, are the pins labelled as to their connections?
Top
#191775 - 01/11/10 11:31 PM Re: Crawfoot extension cord [Re: aussie240]
wa2ise Offline
Loc: Oradell NJ USA
I added a picture of the plug without its cardboard insert, and the hot pin (connected to the black (hot) wire) looks to be marked as reddish brass color. Which is consistent with a diagram at http://www.accesscomms.com.au/images/reference/Mains%20Plugs%20&%20Sockets/POWPLUG.GIF at http://www.accesscomms.com.au/reference/powerplug.htm
Same thing at the other end.
Top
#191776 - 01/12/10 02:12 AM Re: Crawfoot extension cord [Re: wa2ise]
aussie240 Offline
So, the live/neutral polarity is the same. Regardless of that, I'd have no hesitation using that extension lead here.
If these fittings were still commonly available in the U.S. I'd bring some in to make an interesting change to the same 2 or 3 local brands of plug and socket. And we have the same size wall box (even the screw threads are the same)which means the wall outlets could also be used.
Top
#191784 - 01/12/10 03:06 PM Re: Crawfoot extension cord [Re: aussie240]
wa2ise Offline
Loc: Oradell NJ USA
These occasionally show up on the American eBay. The hard part is finding the specific auction using keywords non-electricians would use to describe these plugs and outlets. "old", "vintage", "bakelite" or even "crawfoot". Be aware that there is a 30amp version that looks quite similar, but are actually a little larger.
I noticed that modern Australian outlets have switches to turn the hot wire on or off. I would guess that this is a code requirement. If you did use a vintage American crawfoot outlet, you might be able to meet this code by having an American light switch (some are rated at 277VAC) right next to it in the same box to switch the outlet's hot wire.
Top
#196212 - 09/17/10 08:24 PM Re: Crawfoot extension cord [Re: aussie240]
wa2ise Offline
Loc: Oradell NJ USA
While surfing eBay.au (was looking for interesting tube radios) found this auction:
American looking Aussie outlet ebay auction "The electrical mechanisms in DECO "BAKELITE" range are manufactured in Australia by Clipsal and carry full approvals." Wonder if that approval is by a recognized authority you use in Australia. confused
Top
#196221 - 09/18/10 04:44 PM Re: Crawfoot extension cord [Re: wa2ise]
gfretwell Offline
Loc: Estero,Fl,usa
I have two 30a amp extension cords (25 and 50 feet) with the 10-30 plug and receptacle plus a short 14-30p to 10-30r adapter cable for using my big pressure cleaner and welder at other people's houses from their dryer plug.
_________________________
Top
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
